But yes, if it's outside the recommended range of 10-14 then it isn't working like it should, aka needs to be changed. Make sure the injector contacts are clean (no green corrosion). Search for "12 volt mod" if you plan on keeping the old style injectors. They are known to fail, more so if your Z sits for long periods of time.
